Which consumer unit?
28 Jun 2004
Can anyone suggest the best consumer unit for a five bed place with lots of electical units.
I was looking at the 16 way split load MK Sentry, is it any good? Is there better?
Also, there are two thermostatic showers (fed from an unvented tank), do these need to be on a MCB?
Rather depends on where you are going to locate the consumer unit and how much space you have.
MK is a good brand - there are many sparks who would choose MK over pretty much anything else.
MCB are the little circuit breakers that go in the consumer unit. I think you mean RCD. I am assuming that the showers are electric - yes they must be protected by a 30mA RCD and yes they would be on an MCB.
Do you know what type of supply you have? TT, TN-C, TN-C-S, or TN-S? Do you know how to make the supply to the consumer unit safe when you come to replace it? If not, I'd strongly recommend that you get a competent electrician in to advise you. They shouldn't charge you for the initial quote.
Michael
What kind of shower is it? When you say thermostatic, do you mean a mixer shower? If not an electric shower, do they have pumps?
Yes, the shower is a thermostatic mixer thats fed with mains pressure water directly from a Megaflo tank, so not an electric shower and no pumps. Does that sort of shower normally have any electrical connections?
Not sure what sort of supply I've got, how can I tell?
I'm getting a sparky in to do the job, but I want to make sure that I end up with something thats good for me.
Possibly supplementary bonding, depending on how it's supplied, plumbing-wise, but other than that, no.
http://www.tlc-direct.co.uk/Book/5.2.1.htm
Why not let him supply the CU?
AndyDavis said:
Yes, the shower is a thermostatic mixer thats fed with mains pressure water directly from a Megaflo tank, so not an electric shower and no pumps. Does that sort of shower normally have any electrical connections.
No electrical connections required in this case
Sorry to an an@l pedant, but as Ban said, no connections apart from supplementary bonding.
Just want to make it clear.
