I recently got my house re-wired and in the lounge I have two sets of low voltage (24v) spotlights. One circuit has 12 x 50 watt bulbs (600w) and the other circuit has 6 x 50 watt bulbs (300w).
I designed it this way on the back of buying a 2 gang 1000watt dimmer switch which states that each gang can take a minimum of 150 watt and a max of 1000 watt.
However when we did the big switch on both switches give off a very loud buzzing noise (too much to live with) and in fact the smaller load 300 watt switch gives off an even bigger buzz and after 10 mins the light starts to flicker and a burning smell comes from the switch.
I first thought it was a faulty switch and the supplier sent me a replacement free of charge - but when we switched it over it still has the exact same problem.
All the other circuits upstairs were wired the same way (transformers with each light) but with lower loads (up to 300w) and all work ok off standard dimmers - Can anyone explain? Do i just have a cheap 1000 watt dimmer as it was off ebay or is there a bigger under lying problem.
Problem is house is now all decorated nearly and not simple to run another cable
All help will be much appreciated
