Pitch 17 degrees. Angle of cut to seat 17 degrees. Angle to plumb cut ridge and heel 73 degrees
Wall to back edge of plate = 115ins
115ins = 2920mm
2920 less 47mm width of ridge plate = 2873
2873 run gives rise of 878 on the pitch line (hypotenuse) plus HAP (height above plate). Come back to this in a minute.
Slope of rafter from ridge plumb cut to heel plumb cut will be 3004 plus what ever overhang you require.
If rafters are 50x200 these will be delivered 47x195.
Pitch line and birds mouth plumb cut will be one third up rafter depth = 65mm. Seat cut will be approx 210 long. Save your cut our, reduce and stick back on to cut to continue rafter down to plate.
On 47x195 rafter, length of plumb cut at 73 degrees will be 203mm less 65 = 138mm which is HAP.
As above rise to pitch line on 17 degree was 878 plus HAP of 138 =1016 therefore top of ridge plate is 1016 above wall plate.
Would suggest that you use 47x195 for ridge plate to collect full depth of rafters.
Make sure plates are level and parallel.
Not being negative, but if you have windows in wall above roof, then you will not get a 17 degree pitch in due to height of rise.
If you do not understand what we have wrote then PM us your address and we will put a self explanatory drawing in the post.
All measures are based on 47x195 rafters.
oldun
