Hi guys,
Was just out a job there where the boiler flue is churning out black soot and blackening the wall.
The burner is a 1992 Bentone Electro Oil (serial No 031201000010039 (unless info!!). Has a danfoss pump fitted and a riello Capacitor!!!
I was recently called out to bleed this burner and i re set the burner pressure to 8 bar.
Basically the owner has noticed that the boiler is now spewing out soot and the wall is blackened. He is "relatively" certain that this has started happening after he ran out of oil. I checked the flue as well and it has large holes just below the terminal so this will defo need to be replaced.
He assures me that he hasn't touche the air adjustment. Is this a little red arrow at the top left corner of the burner?? I don't ahve the manual for it yet.
What else should i be looking for on the job??/ How can you do a smoke test if the flue is faulty???
As always any help.advice would be brilliant
Grill
Grill
