1995 mitsubishi delica 2.8td intercooler ( fuel help )
5 Jul 2008
Clackmannanshire
Hi folks
I need a little help with a fuel problem on my 1995 mitsubishi delica 2.8 td intercooler.
Ok i had starting problems which i found out it was the fuel pump seal leaking and sucking in air so i took the pump out and replaced 3 seals on it , the main seal was on the center of the shaft so was easy to replace without having to take the pump apart .
Its all back together with timing all set up the way it should be but im not getting fuel from the pump to the injectors ( help ).
I have primed and bled the filter till the fuel was coming out of the line that connects to the pump , also loosened the pipes feeding the injectors to try bled out the air but no matter how long i turn the engine over nothing comes out the fuel lines from the pump .
I tested the fuel cut solenoid on the pump and it seems to be working ok .
Any help on this is much appreciated.
John
