Hi Guys
Need some advice please.
Job I am doing next week entails adding on a shower room with a thermo valve from a gravity hwc.
The current setup has a thermo valve with a pump from the cylinder.
Is it possible to run the 2 showers from one pump or can I install 2 pumps?
Not sure of the hwc capacity yet.
The client requires 2 showers in operation together with good pressure.
I am thinking 2 pumps would cause air to be pulled in even with a surrey flange or am I incorrect?
Could one pump feed the 2 outlets with reasonable flow and pressure?
Many thanks for your input.
Pete
Pete
