Since moving into my property a few months ago, I have been annoyed by the 2 way lighting I got on my landing light. This light can be controlled by 2 light switches, one downstairs and one upstairs, only problem is that one switch has to be in a certain position for the other switch to operate the light!
The wiring puzzles me even more - on the upstairs switch I have 3 flex one has a red and black one has a single red, and the other has red and black. The red from the 2 core flex goes to the common on the switch and the black terminates in a connector block with the single red. L1 has red and L2 from the 3rd flex.
At the light fixture I have 2 flex coming out the wall, one with the single red and one with red and black. The single red connects to the neutral on the light and the live from the other flex connects to the live cable on the light. The neutral from the flex just terminates in a block - It was attached to the earth point on the fixture but i disconnected it from that!
At the downstairs switch I have 2 flex 1 has live and neutral in L1 and L2 respectively, and the common has a single red (although this single red cable seems different from the on on the other switch as it sppears to be a 2 core cable with the neutral cut (rather than a single red in a white flex which is seen on the upstairs switch and at the light fixture).
Sorry if its long winded, but i tried all the logical text book connections but I blow a fuse every time. If anyone has any pointers or suggestions it would be greatly appreciated, otherwise I just got to live with it!
By the way its relatively old wiring so no earths.
