you can buy a two way dimmer switch, just change one type of switch for another.
If you have at present two 2way switches operating 2 lights. then you will require 2 two way dimmer switches. these may not fit into the switch box you have at present. therefore you will require a dual switch box. to replace the one you have or use a surface mounted dual box and fit ove rthe existing switch box. It is possible to buy a small twinn dimmer swotch but not advisable
Following emmanuelj's comments, you should also be sure to buy the right dimmer switch if this is runing a florescent light or low voltage light you will need to buy the appropiate dimmer switch.
