hi, could you tell me how to wire up 2 way switching using 3 light swithes. i have 3core + earth cable going to each switch, with twin and earth cable going from the last switch to the light rose but am not sure what wire goes were in the switches?
I take it they are class 2 (double insulated) which do not require an earth although you need to verify this, either the fittings will be labelled up (square in square) or the instruction sheet will tell you.the spots only have 2 wires to them
