hi i am building a shed to build my kit car in its about 10-15 meters from my house i want to buy a clarke mig elder 151en ,Unit operates from 230v, 1ph power supply (30 amps minimum) ,i know that a normal plug socket gives out 13 amps but does an eletric cooker socket give out 30 amps and if so can i add an extra socket to the cooker wire and only use the welder when the cooker is off ,or do i have to wire a whole new circuit up? .I dont mind using an extension cable because i wont be welding all the time and to cut down on cost as i am skint. if anybody has any ideas or surgestions it would be brillant
cheers Ian
cheers Ian
