Sound like a large property, how many bathrooms is in the house.... sounds a bit big for a combi boiler on the HW side??
Its only a system boiler.
It has a 170 li unvented which goes cold during the second shower.
BUT there is no balancing valve on the cylinder ( which would lower the reheat ). There is also an unused pumped secondary loop which is incorrectly connected and would worsen the situation.
If I get the job then I will consider if I should fit a device to enhance the reheat if the heating is on.
Tony
Tony
Hi Tony
Is the proposed boiler not going to be a combi though? Although I see what you mean, even the system boiler will have the same size integral pump.
When you say balancing valve, do you mean the valve before the cylinder to balance the heating and HW input?
That would be fine if, at the time, only HW was required!
But what if both CH was required ( at a lower temp of say 55° ! ) as well as HW reheat ( @ say 65° )
Tony
