93 corsa rear washer hose
22 Nov 2005
Devon
I have found my rear washer pipe has broken at the point where comes from bodywork to rear tailgate. It looks like some one tried to push a piece of flexi 6mm bore pipe over the top to make due, but keeps working way off. Id have used a longer piece of pipe if i could find 6mm bore anywhere, but anyone have idea of route of pipe after enters the bodywork and is it a job to big to bother with? I have already had a look from filler tank when i took frontcovers over cabin filter off and see it travels down by front door/wing. any idea where it goes then and is it just a simple pull throught. somehow i think not.
If it's a join between the tailgate and body, it's probably supposed to be there.
Try vauxhall for a new bit of joining pipe............ if it's supposed to be there they will be able to get it.
