I want to put rigid foam foil backed insulation between my rafters and probably on top at a later date + boardout.
I've measured my joists and there actually 97mm so my question is do i buy 100mm or 95mm board.
Reason I'm not sure is that if I use 100mm and board I'm worried it might push the plasterboard down. 95mm will obviously sort this but then leave a small gap were condensation might form.
Hope you can help. Thanks
