B
BigBurner
How much is this?
I have no idea and don't care as it's irrelevant to the question.
Is isn't irrelevant.
I could install a system that would be out of this world, if the poster can't or don't want to spend that sort of money, then he has to accept 2nd best.
The mainsboost is one solution that would work, so would be money well spent in my opinion.
One of these can be made up quite cheaply. What appeases the water companies is having the pump draw less water that what the mains pipe can deliver - a water flow regulator before the pump ensures this. The water compys do not like suction on the mains pipe in the street as water can be draw from other houses into the main pipe causing contamination. The pump trickle charges the accumulator to higher pressures, not creating negative pressure on the mains pipe.
Accumulators and high flow combis are a great match when the mains pipe is poor.
