I note in approved document H, section H3 - that 'Surface Water Drainage' and 'Drainage to Paved Area's' gives guidance on where rainwater can go, ie, to a drain, soak away etc etc.
However the first part of the section 'Gutters and Rain Water Pipes' gives no explanation of where rainwater can go, only explanation is where a roof may have no gutters at all.
This first section obviously refers to 'roofed' areas (although I see no reference to it) ... can rainwater goods discharge to a flat area of natural ground, or must it go to a soakaway or drain.
The rainwater should in theory soak directly into the area of ground around the discharge., I have thought of buiding a 'detention pond' which might be quite nice, not sure.
Any thoughts appreciated.
