That was a flood damaged one that went in the bin
As you've been told, that's a DIN mounting rail, not a bus bar - the bus bar doesn't go beyond the main switch.In this photo you can see the bar runs beyond the edge of the main switch
It's full. You could probably get two extra circuits by getting rid of the left hand RCD and replacing all the MCBs currently fed from it with RCBOs, plus RCBOs for the two new circuits. However, that would require a new, longer, bus bar (assuming you could get one) and a little bodging, and would probably be pretty expensive (RCBOs are still not cheap).I'm not entirely convinced it is, but I'll take your word for it
It can be overcome, but will come at a price for an extra couple of ways, might be more cost effective to get a larger board.The bus bars come in standard lengths so if that's the only problem then it can be overcome!
