Hoping someone can help identify whether these pipes can be used to add a radiator to the existing system. The top pipe is a 22mm Flow with a drain valve on the end and the bottom is a return which has been capped after being reduced to 15mm.
Can a tee be inserted on the flow and the return just extended in 15mm or are the sections of pipe up to the drain valve / cap serving a purpose?
Thanks,
Thanks,
