- Joined
- 13 Jun 2008
- Messages
- 1
- Reaction score
- 0
- Country
I am English and living in the Netherlands. I have removed a stud wall and knocked the plaster of one the walls in my house to expose the brickwork underneath. In the stud wall was a plug socket about 2 feet from the floor. The wire ran through a plastic pipe up through the ceiling, behind the stud wall.
I am going to replace the plastic pipe with a metal one and leave the socket wire running over the exposed brick instead of re-routing or hiding it. For an industrial look. I will also replace the socket itself.
Now at the bottom of the wall is a gap of about 4 - 5 inches between the floor and wall where the stud wall framework sat. it is recessed about 2 inches below the surface of the flooring tiles. To fill this gap I was going to inset a piece of wood running the length of the wall flush with the floor and have spotlights shining up on the exposed brick. I have seen the plug in spotlights that would be suitable but I would prefer to wire these into the plug socket if possible. ( I use both the sockets on this wall already )
Is there a way to wire a bank of about 5 spotlights using the transformer provided straight into the plug socket or take a feed from it? Here are some pics of the area I am working on //www.diynot.com/network/yorkie2005/albums/
Any help or advice would be appreciated,
Marc
Marc
