- Joined
- 26 Nov 2017
- Messages
- 65
- Reaction score
- 0
- Country
Hi all,
I was wondering if someone could help me with blocking off an alcove with a stud wall. We have this odd alcove in our dining room that is currently shelved. However the alcove isn't the height of the room, as the chimney goes off to the left above it. It just kinda looks a bit crap. So we are looking to block it off and have a full wall. We are getting a stove installed in the chimney next to it. I was wondering if someone could give me some tips on wood, hardware and techniques on how to do this please.
HxWxD 1770x880x370mm (height is 1890mm to the floor)
I have very successfully built a pony wall for my kitchen before after receiving great advice on here on exactly what to use and how to do it.
Here's what I'm thinking (might be overkill in places):
1. Do I need to vent the finished wall at all?
2. The recess is at a party wall of a semi, so it isn't on an outside wall. Should I insulate the recess before attaching the plasterboard? Maybe soundproofing?
3. Do I need to use plywood AND plasterboard on the stud? I'm pretty sure this will be a "no", I only ask as I have quite a bit of plywood going spare from building the pony wall. I think its 12mm.
4. Currently, the bottom shelf is just above the skirting board, and the space beneath is filled with insulation. There is a small door cut. Should I remove this bottom shelf entirely along with the skirting board, and build the stud all the way to the floor, or is it ok to just use the bottom shelf as-is?
5. What size centres should I use for the sides and top timber?
6. Do I need more than one noggin between the vertical supports? The more, the better the structure?
Thought this was a good video:
Apologies for the large post, just want to make sure I get it right.
Thanks!
- Timber: standard C16 carcassing timber (or C24) will be sufficient? Something like 3x2?
- The floor is timber, so fix the sole plate and spacer blocks to floor with something like 10mm coach screws (I have leftovers from the pony wall) at something like 200mm centres through large square washers. See question 4 also.
- Side and top are both brick, so brown plugs and 5.0 or 6.0 x 100mm screws.
Thanks!
