i have just purchased a set of beam detectors, they are marked as 300m indoor and 100m outdoor. Anyway i have them installed in my garden, approx 15m apart, and approx 700mm off the ground. anyway wired them up and aligned them all appears to be fine. i set the reaction speed right down to 1 which is the quickest. now the problem.
no false alarms so far, but, in the centre 5m between the trans and reciever i can walk through and even stop inbetween the sensors without the alarm going off. where as the 5m from each detector i can run through and the alarm picks me up. Its as if the beam is curving around me in the middle. Is this common or is the unit faulty?
