Today I did a load of washing and it worked fine.
I then started a second one and when I looked at the machine, the timer showed the number 1 and the light was on prewash.
the washing had not been done as the detergent gel was still there on the machine's drum. there was water in the bottom of the drum.
I put the switch on reset, opened the door and removed the clothes.
Then we tried the 'pump out' and the machine kept going to 1 and prewash and not functioning.
after hitting reset for a while, we managed to do a pump out.
thinking the machine was working we put the clothes back in and again it looked like it was going to work for 2 minutes and then went back to 1 and prewash light and not working.
It seems to regularly do this now, we managed to do a short spin to remove the clothes from the machine. but it's not working fine.
I have now turned it off at the mains, and will leave it to rest until tomorrow.
Does anyone have any clues on what the problem is or what could be done before we have to call a plumber in?
thanks
thanks
