When room thermostat switches central heating off, there is a sound of air rushing in the system,followed by severe banging noises from the pipes. I have now switched the whole system off until I find a way to cure the problem
Also,when I run the hot water tap to fill the bath,the tap slows to a trickle and eventually stops running.The bath is only one third full at this point.
Any advice would be greatly appreciated. Thanks.
