- Joined
- 13 Aug 2010
- Messages
- 1
- Reaction score
- 0
- Country
Hi, I have a conventional 3 bdrm home w/2 baths, one up and one down. I have a 750 gallon water tank about 80 feet above the house level, and have been using this system for 20 years. My wife left the hose on her flowers two nights ago, and ran the tank dry in 4 hours. The next morning we had no pressure even with enough water back in tank to have taken a shower. It has been 2 days, and I still cannot get pressure back. I suspect a problem with the hot water tanks, which are 40 gallons each and located on 2nd floor. I have tried opening all faucets, but get little to no air bursts. I hooked a hose to the hot water tank drain and tried letting them run for about 30 minutes, with no results. It seems like there is little water going into hot water tanks on the supply side. I can open the lowest hose bibb on the outside of house and get a respectable flow, but very little pressure. I can barely get enough hot water in lower shower to take a shower. This happened once before the day we first hooked up the house when it was new 20 years ago, and almost drove my plumber crazy. If finally flushed and has worked flawlessly until now. I have done everything I know that we did back then, but nothing seems to work this time. Can anybody help? Thanks, Lynn
