I hope someone can help
I had an existing kitchen, with the sink waste running into an un-vented 40mm stack, this went through a u-bend. the washing machines waste always had trouble when it was above the sink ubend so now it is connected directly to the top of the small stack, all goes well.
I have now fitted a shower and basin into the same room.
The basin has an anti syphon bottle trap and the shower uses an Hep20 valve, this runs into the same stack at it's lowest point.
The basin has no problem draining at all but the shower tray eventually overflows, I didn't think it was a vacuum problem due to the Hep20 valve and the anti siphon trap on the basin being able to let air into the system.
However when my washing machine connection is removed and the stack is open to the air, the shower tray drains away perfectly. I think my problem is more positive pressure than a vacuum problem.
A local plumber gave a solution to run the stack outside and have it permanently vented, which is good advice and would cure the problem, the thing is I'm lazy and was hoping that there was a magic valve I could put into the system that would allow the air to escape.
Any ideas anyone?
Any ideas anyone?
