Hi all,
I have a Worcester 28i which has a problem with the Red & White rubber pipes that go the the air pressure sensor frequently filling up with water/condensation.
Once they are cleared and the water is removed from the pipe the boiler operates for about 12 hours before needing the process repeated again.
I have already had the plumber who installed the boiler to look at it three times and says there is nothing wrong with the installation of the boiler and it is most likely a fault. But claims not to really be a boiler engineer. Despite him seeing first hand the flow sensor tubes having water inside them which is stopping the boiler from igniting.
Is there anything i can do to stop this issue?
Thank you!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you!
