I have a 2.3 bar shower pump that feeds two mixer showers.
The pump is very close to the hot water cylinder and theres a direct cold feed from the water tank. The pipework is 22mm and then splits to 15 for the two showers. The pipework is grey plastic pushfit.
The shower closest to the pump pipework works perfectly everythime. The furthest shower sometimes doesn't come on at all when you switch it on especially if you have not used it for a few days. The way to get it working again is to switch on the first shower and whilst that's running and the pumps kicked in, switch on the second shower. Sometime shaking out drops of water on the second shower whilst it's on, then causes the pump to kick in but usually there are no drops of water coming out when you switch it on.
Any ideas why the problem is happening?
Thanks.
Thanks.
