I have an Alpha CB28 CH/DHW boiler installed in March 2005 and have a leaking Diverter valve. This is the second valve that has been installed both suffered the same fault.Leaking through the weep hole on the underside. The first was I beleive leaking when I moved into the property in 2007
Both valves started with the occasional drip which became serious after a while. The second valve was fitted Oct 2009 and has started leaking again.
Is there a design flaw with these valves should I kick the boiler into touch and purchase another make or just have the valve replaced again?
Expensive job every 2 years.
Paxo2
Paxo2
