Alternatives to Keston boilers - need narrow flue
Discussion in 'Plumbing and Central Heating' started by simonc1, 25 Oct 2010.
  1. simonc1
    25 Oct 2010
    3
    Thanks Received:
    Essex
    Country:
    I'm looking to have a boiler installed that has a narrow flue - perhaps 50mm, due to its location within a listed building. The keston is attractive as it offers a narrow flue, but there are lots of questions about reliability.
    Is the keston range as bad as people make out? If it is, can anyone recommend a manufacturer who offers a narrow flue option?
    Thanks.
  2. 45yearsagasman
    14 Mar 2010
    5,890
    Thanks Received:
    1,035
    Norfolk
    Country:
    Baxi have boilers that use either a concentric flue or can be adapted for twin flue use which is what your Keston uses.Not sure of exact models but we have a few Baxi guys on here who will be able to advise.
  3. SimonH2
    4 Nov 2010
    3,902
    Thanks Received:
    440
    Cumbria
    Country:
    I was about to ask much the same question - are Keston as bad as people make out ? I've been puzzling how to do the flue when I have to change the boiler as the garage doesn't have an outside wall. I've had a couple of people to look and they want to go through the bin store and come out on the steps (thigh height coming down, face height going up), and then run a plume diversion kit half way across the wall to get the flue away from people. Now I don't like lots of external pipework, and I really don't want loads of flue all over the back wall.
    The garage door is set in from the back wall of the property to form a carport sort of space with the bin store off it. The current (old) boiler flue dischrages into this space and it's not really acceptable as it creates wetness that has already made the boarding fall off. It wouldn't meet regs anyway for a new install.
    To run a flue out from here would mean going over the steel RSJs that support the back wall - and there's only about 2" gap before I'd have to cut into the blocks of the floor above. When the guy at the plumbers merchant told me about the Keston boilers with the 50mm plastic pipe I thought this could be just the ticket. I am rather concerned about their poor reputation though.
    I've just had a read of the manual for the Baxi Solo HE range. I reckon I could probably manage the 70mm plume diversion flue pipe, BUT I'd have to take the flue extension either (depending which way I routed the concentric flue) :
    - straight off the end of the concentric flue (ie just extend the central tube in-line) or
    - fit the plume diversion kit with the outlet horizontal (the manual specifies it to be vertical).
    I don't think the Baxi twin flue setup would work for me - firstly the pipes are a bit big, and all the diagrams show them being recombined to a concentric terminal.
  4. mickyg
    24 Aug 2005
    15,998
    Thanks Received:
    3,319
    Cornwall
    Country:
    if you can manage 80mm, you could use a twin flue adaptor off most boilers(glowworm, atag etc...). and yes kestons really are that bad.
    Remember all joints of any flue will need to be accessible for inspection
  5. transam
    20 Nov 2009
    12,517
    Thanks Received:
    1,985
    Surrey
    Country:
    The only other boiler that I know off that used a keston type set up be it in ally not plastic was the Quantum ?? but I think ?? that they ceased production not to long ago ????????? cannot remember who they were something ? engineering up north ? stainless steel engineering firm make parts for BA ?? (maybe)
  6. picasso
    8 Apr 2008
    7,681
    Thanks Received:
    1,694
    Essex
    Country:
    • Thanks Thanks x 2
  7. pampers
    3 Oct 2006
    637
    Thanks Received:
    93
    Sussex
    Country:
    Keston are worse than you have heard truly a stack of steaming (well usally not steaming when i see em as they broken) poop.
    • Thanks Thanks x 1
  8. SimonH2
    4 Nov 2010
    3,902
    Thanks Received:
    440
    Cumbria
    Country:
  9. Boilerman2
    10 Jun 2009
    5,229
    Thanks Received:
    1,011
    Suffolk
    Country:
    There are Kestons, but there are no OLD Kestons!!! ;)
    • Thanks Thanks x 1
  10. ChrisR
    24 Jul 2003
    23,728
    Thanks Received:
    1,194
    London
    Country:
    It's Ok we know you're a stoolie from the Viessmann factory up the road from you ;)
    They're okay - nothing special and a bit expensive, not particularly reliable, come with a lot of hype ...
  11. gassafeengineer
    6 Oct 2009
    1,983
    Thanks Received:
    290
    Cumbria
    Country:
    dont buy a keston ever never ever ever no way. do without heat before you get one of them
  12. jimstreet
    15 Apr 2009
    23
    Thanks Received:
    Berkshire
    Country:
    Baxi/potterton do the powermax boiler which uses twin flue, and this is not plastic flueing, its metal.
    oh yeah and nearly forgot to slate keston boilers before i left!! i would rather have intimate relations with my dad, before fitting a keston, or reccomending them, they are awfull boilers!!
  13. SimonH2
    4 Nov 2010
    3,902
    Thanks Received:
    440
    Cumbria
    Country:
    Twin flue isn't uncommon - the manuals for most of the boilers I've looked at have included details of twin flue setups. However, the flues are 80mm and so for me not much better that a standard 60/100 concentric flue. Actually, I think that's about the size of a plume diversion kit on most systems - so that could be one other option.
    As far as I can tell, the Powermax is an attempt at an integrated thermal store & boiler - what little I can find on them isn't complimentary about their reliability :rolleyes:
  14. jimstreet
    15 Apr 2009
    23
    Thanks Received:
    Berkshire
    Country:
    As far as I can tell, the Powermax is an attempt at an integrated thermal store & boiler - what little I can find on them isn't complimentary about their reliability :rolleyes:[/quote]
    yes simon, the powermax is a thermal store, but i have worked on a few powermaxes over the last few years, and pretty much all i have ever changed is pumps, and plate to plate h/e. so not too bad reliability
  15. kevplumb
    18 May 2004
    23,692
    Thanks Received:
    921
    Georgia
    Country:
    tbf
    just about anything is better than a keston :cry:
Loading...
Share This Page
