I know....No requirement for that, it is part of SP's system and part of the M in PME
Surprised they didn't use thermite welding though, if they like toys to play with...
I most certainly would be arguing that very strongly. They surely have a contractual duty to provide you with a satisfactory and safe supply. If something in someone else's house is preventing them doing that, they've surely either got to sort it out themselves, require that someone else to get it sorted out or disconnect them?Now we hit the catch 22. SP are now saying that if the fault is internal to another property there is really nothing they can do to sort it out. .... So now leads me to the question. Since this 'fault' is affecting my supply into the my property, could I argue that it IS SP's responsibility to sort this out as at the end of the day, as a DNO, they have to supply me with a stable, reliable, safe and working supply. OK the fault is maybe not on there grid, but oblivious to this, they are not meeting there obligation to provide a supply to that spec. Could I argue this?
I've been following this fascinating thread and to follow 'rebuke's' suggestion could (I've no idea) a badly installed solar system, poss with backup batteries and inverter cause this 'feedback' ? I was thinking along the lines of a DIY trying to get the FIT
I'm totally lost. I thought was that, quite apart from your 'local' issue of RCD tripping, the ongoing problem was very substantial currents flowing in the earthing conductors of yours and many other properties. Upgrading your CU and thereby replacing a (possibly) damaged RCD will surely not have made any difference to that. It may have cured your immediate problems (RCD tripping) but I would have thought it left the other, potentially worrying and dangerous, issue still there for you and your neighbours.IQA came out this morning, and had a hunch that the RCD, although testing OK, may have been mechanically damaged due to the amount of times it has been tripping.....
So, the pictures should speak for themselves, but two hours later, new split RCD board installed and NO TRIPPING!!!!! and I mean no tripping, not even any nuisance trips caused by any pre-existing problems that were unknown.
