Hello forum,
I've extended a brick shed, the side wall of the original shed which has a window is now the inside wall of the new extension. I would like to place a workbench up flush against this wall but the window sill prevents this.
Can I angle grind off the protruding part of the sill - 5cm ?
Or is there rebar in the sill which would be problematic. It sounds like a very small space gain but the space is really limited and this would make the workbench fit snugly rather than out from the wall.
All info / advice appreciated.
