Another light switch question
9 Dec 2004
I have recently split the lighting circuit of a house I am preparing for rental into 2 circuits (upstairs and downstairs). The downstairs circuit comprises Lounge, Kitchen and stairs lights. The question I have is regarding a triple switch that controls all 3 of these lights. It is the only switch for the kitchen light but the other 2 each have an alternate switch. From what I have seen of the way it is wired, there appears to be only 1 permanent live into the switch (from the kitchen) which is directly connected to the live terminal of each of the 3 switches thereby allowing the other 2 to operate 2 way switching with just T&E cables rather than 3 core and earth.
I have checked each ceiling rose and all seem to be correctly wired as part of a radial circuit, all have correct live, earth and neutral connections. The question obviously is "Is this safe/acceptable practice?". I do intend to have the house tested by an electrician before letting it out as a precautionary measure but I would like it to basically just be confirmation that everything is ok. Replacing these wires with 3 core and earth would be a major job and involve taking a lot of plaster off. I can see the logic why the circuit works and I can't see anywhere that wires would be taking too much load but I haven't seen this set up before so need to find out if only for peace of mind and the education.
as long as all three lights are on the same cuircuit this is fine (its also done accross cuircuits a lot which is not good)
from what i gather three and earth has only become a common product relatively recently and so wiring like this is common in older installs
Thats a relief, I really didn't fancy the extra work. I could see how it would be bad across circuits though because of it supplying a live to a circuit that had been turned off.
