Yes, that's essentially it. Of course, (just like everything else) RCDs do fail, so if you are heavily into 'belt and braces' then you could have the two RCDs. However, as I said, that would mean that there would be no telling which (or both) would trip in the event of a fault, so there would still always be a risk that all the house circuits protected by the in-house RCD in question would be lost in the event of a fault in the summerhouse, even if there were an additional RCD for the summerhouse.Ok I think I understand, on the previous job I used a rcd and a fuse, but I see your point because on the earlier one there was no rcd protection on the mains only a cb, hence on that I used as stated a rcd, armoured cable to a fuse box in the shed, the belt and braces approach again! so on this one only a fcu is required, fair enough.
If one wanted to avoid the possibility of a summerhouse fault taking out circuits in the house, the only way of achieving that would be to have the summerhouse circuit totally separate from the house's RCD-protected circuits - which is probably a degree of complexity which you wouldn't want to contemplate. In reality, tripping of RCDs is sufficiently rare that the degree of potential inconvenience we're talking about is probably pretty minimal.
Kind Regards, John
