Any recommendations for new combi?
5 Feb 2007
Hi All,
Hoping you can help. Just purchased a small three bed semi and would like to replace the existing boiler (old baxi with hot water tank) for a modern condensing combi boiler. Please would you be so kind as to recommend the best and most reliable products on the market with good enough water pressure for a decent shower?
I've been quoted around £2300 to get the boiler replaced. Sound fair?
Any help most appreciated.
Many thanks in anticipation,
Rich
whats the water pressure like
did the estimator check this?
Why do you want a combi?
how many bathrooms do you have
Many disagree but I hate and loathe combis, takes ages to get hot water, if the thing breaksdown (and it will) you have no back up whatsoever
and if some numpty nuts fits one on a mains water supply that you can piddle faster you are stuck
well that will teach me to try and been fancy
Ok i meant did the bloke who came out to have a look check the water pressure and flow rate
Hi Corgiman,
Only one bathroom upstairs and small wc downstairs. Water pressure wasn't tested but plumber located nearby so maybe he knows. Pressure from opening the tap pretty high pressure.
Would like a combi for the following reasons:
Current boiler very old and central heating only works when hot water is on.
I would like to relocate it under the stairs and out of the kitchen - so the opportunity is there whilst the house is done up. Don't want to build a kitchen around the current boiler, only for it to give up the ghost later.
Would appreciate the energy saving benefits of a condensing combi
Would appreciate any further comments you may have.
Many thanks
Rich
