Makita make a guide rail adaptor for their routers and their guide rails. The Makita guide rail is compatible with Festool saws/rails (I use a TS55 on a mixture of Festool, Metabo and Makita guide rails)
The big Bosch (GOF2000) also has a guide rail adaptor available for it which can run on the older Bosch rails. The GOF2000 can use the fence and rods off a deWalt DW625 (10mm diameter) and the "hump" that the guide rail adaptor uses is the same size on the old Bosch rails and the Makita/Festool rails
What this means is that I use a Festool OF1000 router with a Festool guide rail adaptor on a Bosch FSN140 guide rail in the workshop (that rail is not TS55 compatible - the anti-splinter is in the wrong place) and a deWalt DW625 with a Bosch guide rail adaptor on a Festool FS 1400/2 guide rail out on site.
BTW my recommendation for routers would be either a DW625 or the big Makita - both pretty bulletproof although the dust extraction isn't in Festool's league. 1600 watts is really a bit puny for worktops, at least if you are trying to earn money at it
