boiler getting very hot making a loud banging and blowing pilot out ive bled all rads bled pump still no joy also pressure creeping up any one out there who can help?
new pump fitted back end of last summer so shouldnt be that i suspect air in the pipe work as i said bled every thing. would draining the system and fefilling help if so hoe would i go about this or is there another way of getting air out?. cheers
What system is it though if you are gravity hot water and pumped heating it may be that this is the first time the pump has been called into operation since you fitted it, or it may be the system is so dirty it has killed the pump already....drop us a few more details.
a new pump was fitted just after xmas last year was was working fine up to summer.. we recently put it on it heats up all rads but then bangs and blows out. the boiler is very hot wen this happens.all rads were fine (no air) except the one in attic which we rarly use bled this till water came out this 1 also gets hot now.there is a dial next to boiler when it gets up to bout1.2 bar the knocking of the pipes starts before boiler blows out. the boiler only controls the cental heating we have another for hot water but the 2 are not conected
How long does it take to get hot, and does it always "blow" out the pilot. I think the apollo has only a high/low stat setting with seperate thermal switches, if the high switch has failed it would go out on overheat and interrupt the pilot.....that's if I have it right about the control stat
Will it still get so hot with the control switch set to"Low"?
it takes about 20 mins before blowing out. itried on the low setting same result. when cold the dial is giving a reading of 0.8 and blows out between 1.7 and 2.bar
It now seems its the pump thats cutting out. Water boiling in the boiler causing the bang and blowing out the pilot. Am i right in saying this would happen? Or is it the boiler that should be cutting out when getting to hot.?The pump is a WILO are they cheapos? Should i invest in a new one? What kind? Please help cheers
