Appying Emulsion with a brush
15 Jun 2004
Norwich
I usually use a roller when using emulsion & get a good finish.
I have two small rooms to paint that have lots of fiddly bits, so I think a roller will be a waste of time (especially when it takes so long to clean rollers).
What I don't want is to see brush marks, is this unavoidable, is it possible to use a brush & get a good finish?
Ant tips / advice appreciated.
Use a good quality synthetic brush and apply several well thinned coats instead of a couple of neat ones.
Have a look for micro fibre roller sleeves 9", Hamilton do a good one. Leaves a good clean finish. Probably B&Q or Homebase. If you have a local professional decorators trade store near you then Wooster pro dooz short pile (will need a Wooster frame for this). Use a good synthetic brush for cutting in 3".
when I was training we were made to use a 5" Hamilton brush to paint rooms, hard work.
You should`ve used a 6 incher ;) - thanks for the tip about micro fibre though - I need to keep up :oops:
I did leave a few comments on another thread - but the jist of it is - take the paint from a bucket not the tin , dip the tip of the bristles then tap once on the bucket side , then work fast and light with random strokes , keep a wet edge ;)
