Aquadard Hydroflow
11 Mar 2008
Kent
I have recently had a WorcesterBosch Combi Condensing boiler installed into an existing radiator system. In the bathroom there was already installed an Aquadart Hydroflow shower which until that point had been a bit of a dribble because the tank was probably not high enough. Because the shower had been built in when the cottage was converted the plumber said "wait and see how it is with the mains pressure" because replacing the shower would be a major building project, like knocking down a wall!
At first the shower was great! Powerful flow without having a power shower! But, the more I use it the more the head drips when the shower is turned off (both on the unit and with taps below the unit).
Does anyone have any idea if washers need changing? where they are or how I get to them? Or a replacement unit likely to fit the same pipes which will work on the system above?
