Can anyone help please. I cannot open the door of my Ariston washer. the door handle appears not to be connecting to anything. The cycle has finished and the display confirms this but the door will not open.
Broken door handle assembly.
Get some string, feed it between the door and the machine (start at the door handle side), work it around then pull back to open the door.
