Ariston microsystem 21 keeps failing to ignite
10 Jan 2010
Surrey
Had this problem ever since the boiler was installed(about 3years ago),i had a plumber in who raised the gas pressure and the problem was solved for about 2 months then started again intermittently.The boiler pressure is fine, it starts to spark then doesn`t seem to fire up quick enough and shuts down.I was wondering whether it was something to do with the frost stat as it seems to be worse in the cold weather but didn`t know if it would even get to the ignition stage if this was so.
  • Thanks
Reactions: nrb
their few possiblity it could be but without being infront of it i can not be sure as not 100% sure on that model
but etheir way you need to callout a engineer
if its gas vavle not letting gas through
if its lighting up but rectiving could be pcb or just need a service
or piolt lights blocked
