Can anyone help please. I have an Ariston washer dryer model WD1200 that won't spin after emptying nor turn during washing cycle. I have checked the pump,pressure switch and motor brushes. Any other ideas ??
hi
its almost certainly the module .the circuit board that sits at the back left hand side when looking at the machine with the back panel off.sometimes its just a dry joint or burnt contact where the connectors clip on.pull the wires off and look at the board connectors for burnt solder joints
hope this helps
hi
hope this helps
