Hi There,
Does anyone have any knowledge or experience of an Atlantic F127 electric heater?
They seem simple enough, it has 2 modes Basic and Prog and the manual says Basic means manual, so set the temp and it will kick in or out depending on the current temperature, and Prog whereby it should use the timers.
I've set the timers to relevant start and stop times, however when the time ends the heater just seems to carry on and not shut off.
Its almost as if the room is below a certain temp and therefor the heater still wants to achieve that temp even outside of the programmed hours.
Has anyone ever come across this?
Thank you.
Thank you.
