Can anyone help what is the regs on plastic pipe near baxi blrs, a customer would like a new blr but plastic pipe is connected at least 200 mm of the boiler. which I am unable to change due to location. Was wondering if this would compromise the guaranty.
Check with the manufacturer but in general plastic pipework should not be connected within one metre of a boiler. If a boiler is not fitted to manufacturers' instructions, the guarantee will be void.
I've seen 1, 1.5 and 2m quoted as a safe distance. For me this is only ever an issue if the boiler is at the highest point in a system but as already mentioned if it voids a guarantee then it needs to be dealt with.
