- Joined
- 10 Jul 2004
- Messages
- 14,686
- Reaction score
- 4,313
- Country
Spent 5 hours stripping rebuilding servicing this piece of crap to try and find a leak, WHAT IS WRONG WITH USING PHILLIPS SCREWS, instead of these useless bloody stardrive ****te, re-did o rings and silicone lubed, then had to remove about 1.5 inches of solid brown crud out of the condense Y piece, which was conveniently dripping onto the copper gas pipe and rusting the bottom casing, would it have killed Screwworm to have sleeved the gas pipe in plastic, then had to replace safety valve as it had a mardy as well, also replace the combustion door seals and fit the new locking nuts.
Now tell me this, BG fitted and have been servicing it "apparently" " how come neither Local Building Authority, CORGI, GasSafe, BG, Glowworm any of this lot have picked up on the Combustion Door seals, it would have been notified wouldn't it ????, Glowworm would have had the Warranty card with the Name and address wouldn't they ???, the door seals were pretty much shot, the condensate pipe must have been blocked for a bloody long time, the customer did say the BG guy took 5 minutes to service it !!!!!!, there must have been more paperwork than an Elephant could wipe it's arse on for this boiler, and yet I find it in in this state and old door seals, **** poor if you ask me.
