The hot water in our house has recently lost all flow pressure. When I first turn the tap the water comes out with normal pressure then once it's warm the flow slows down to a trickle.
There is also a trickling sound coming from the pipes that lead to/from the cylinder when the tap is open.
It's a back boiler system, does anyone know what could be causing the slow flow.
Cheers.
Cheers.
