However hard one tries to tell others how to do something safely one is bound to miss out something.
Try writing instructions for making a cup of tea then as some one to follow it by the letter and there is bound to be an error. Forget to remove tea pot lid etc.
In theory if you use not keys or tools you should be safe. However I would not like to put money on that.
I can and as a small boy did
remove the light bulb and stick fingers down the hole to feel what was there. Only ever did it once
But my Wife's dachshund dog while we were out attacked the vacuum cleaner cable. When chewing it the **** (seems I can't use correct name for female dog star'ed out?) must have received a shock so fought back and the cable was in 3 inch lengths when we returned the fuse did not blow and power was still on. How it did not kill dog I don't know.
So now work out a safe system with that in mind! Only safe way is ban dogs in the home. Had a child found that cable it could have killed it. OK using RCD's may help but only with three core cable, dog may not be big enough to radiate an earth to trip it.
So what I am saying is the house can never be safe. All we can do is reduce the risks. This includes removing items which can be used to defeat the safety devices like those silly bits of plastic one sees stuck into 13A sockets which defeat the built in safety functions of the socket.
