Can someone tell me how to remove a bath panel? There is nothing I can latch on to. It matches the floor and there is a transaparent sealant all around it. It does move slightly but I can't work out how to get it out.
hi had a lot of these just cut the sealer all round and scrape it clear of the front of the panel i use an old knife and bend it about 1" from the end then you can feed it under the panel and it should pull out can sometimes need a lot of pulling but move the knife allong as you pull it a bit at a time
PS if the knife does not want to bend try heating it up then it will
Thanks for your reply. I've tried it with screw drivers. Do I need to pull it out from the top of bath panel or should I squeeze something between the floor and panel to pull it?
well tiled panels are a pain in the buttt becauase most are just boarded up with no regard for removal i would try pulling it from the bottom
failing that i would try drilling through the tile only on the joint at a few inches in from each end the put in a screw or better a hook that will give you something to pull with
