I am installing a wall mounted bath mixer. The copper pipes need to be chased into the walls to get around the bath lip....for the rest the pipes will run below the bath. Do I need to isolate the copper pipes from the wall where they are chased? Can I put tile adhesive over the mixer? Does the tile adhesive need to be separated from the mixer housing?
Is there a difference between 22mm or 3/4 inch fittings?
The inlets into the mixer seem to be 22mm or 3/4 inch male? (with thread on outside - I presume ready to take tap connectors). If I look into these connections there is a hexagonal "bore". Is this for a large allen key to take out this male-male connection leaving a female connection? (thread on inside). Should I remove the male-male connection and put some ptfe tape in to ensure a good seal, or do these connections come from the factory in a watertight state? The outlet is female. How do I connect a 22mm copper pipe to the outlet? Does it need a male-male connector which would allow for a compression fitting?
Thanks for all the help.
