Hope you can help!
Bathroom redecoration. Replacing light switch (ceiling pull switch)
Removed old one.
There are 3 red wires plus 2 earth wires (which seems strange) in the void.
Old pull switch had 2 of the red wires twisted together into COM and one red wire into L2 (there was no L1 on the old switch) The 2 earths terminate together inside the switch housing.
Replaced with new switch. Wires were placed in the same positions as the old housing. Doesn't work!!
Am I right in thinking that the old switch was being used as some form of celing rose?
I assume this because two other lights in 2 other rooms have also ceased working and I suspect the two reds which went into one connector are being used as part of a loop.
The switch only works the bathroom light and not any other lights.
Any ideas?
Sorry if not enough info on this.
Removed old one.
Any ideas?
