Baxi 105e fan/flue fault
Discussion in 'Plumbing and Central Heating' started by duvet77, 26 Dec 2011.
  1. duvet77
    31 Oct 2005
    95
    Thanks Received:
    Sheffield
    Country:
    Hi guys (if anyone is reading this over xmas).
    I had the nice present of my boiler breaking on christmas eve! Oh joy.
    I'm getting no hot water or central heating and the fan/flue fault (50°C) light is flashing. I know there are similar threads on here and I've read through a few of them and read the service manual, and the fault finding procedure is:
    1. check electrical and pressure tube connections
    2. check for blockages in pressure tubes
    3. check for restriction in flue
    4. check venturi
    and if those are ok replace air pressure switch, but I've read a lot of posts saying it could be a PCB problem.
    The fan does a couple of rotations when I first turn the hotwater on and then stops, if that is a clue to what's wrong.
    My first question is what, if any of that can I do myself as a DIYer (I've previoulsly replaced a hotwater diaphragm and hotwater sensor if that's any indication of my skill level). I'm not interested in doing anything that might put my family at risk for the sake of saving a few bob, but if I can avoid paying £200 to get someone out then that would be good.
    I'm assuming I can't touch the flue or the venturi because they involve going inside the combustion box.
    Thanks in advance.
  2. Agile
    26 Jun 2004
    61,271
    Thanks Received:
    4,282
    London
    Country:
    Thats correct, a DIYer should not open the combustion chamber.
    However, there is a PCB fault which causes the fan to start for less than a second and then stop. I have seen that problem a few times.
    I am not saying that the PCB is the problem in your case only that I have seen that fault caused by the PCB !
    Cost to repair is going to be about £200.
    I dont remember the exact PCB used on your model but some variants have gas settings on them and those should not be fitted by a DIYer.
    Many professionals dont seem to check those gas settings though when replacing the PCB.
    Tony
    • Thanks Thanks x 1
  3. duvet77
    31 Oct 2005
    95
    Thanks Received:
    Sheffield
    Country:
    Thanks, I kind of expected as much. I think I'll call British Gas and get one of those fixed price quotes.
    Merry Christmas! :(
  4. ChrisR
    24 Jul 2003
    23,728
    Thanks Received:
    1,194
    London
    Country:
    Call BG if you must, but call your local friendly boiler mender person as well - he'll almonst certainly cost you less.
  5. duvet77
    31 Oct 2005
    95
    Thanks Received:
    Sheffield
    Country:
    Yeah, that's probably likely. The reason I considered BG is because they offer a fixed quote where they won't charge you more than that quote even if it takes longer to fix or needs more parts than they thought.
    I guess I could call a local guy too and see what he says.
  6. twgas
    26 Oct 2007
    4,889
    Thanks Received:
    423
    Kent
    Country:
    take a close look at the BG "fixed" price, it's now a 3 tier pricing system.
  7. gazthepottertonengineer
    21 May 2005
    1,294
    Thanks Received:
    134
    Country:
    Why not call Heateam the service division of Baxi! They offer a fixed price repair with no hidden extras and it comes with a years warranty if anything else goes wrong! :LOL:
    • Thanks Thanks x 1
  8. duvet77
    31 Oct 2005
    95
    Thanks Received:
    Sheffield
    Country:
    Cheers guys. I'll look into it further.
    I could do without the hassle on my xmas break!
    EDIT: looks like the tiers are £69, £189, £349 for BG
  9. duvet77
    31 Oct 2005
    95
    Thanks Received:
    Sheffield
    Country:
    Is this one fixed price or a tier system like BG?
  10. gazthepottertonengineer
    21 May 2005
    1,294
    Thanks Received:
    134
    Country:
    1 fixed price depending on where you live and boiler! But at least you know you will get a baxi engineer who carries 90 percent of the parts for that boiler so won't need to keep coming back like BG! :LOL:
  11. duvet77
    31 Oct 2005
    95
    Thanks Received:
    Sheffield
    Country:
    Do you work for them by any chance? ;)
  12. gazthepottertonengineer
    21 May 2005
    1,294
    Thanks Received:
    134
    Country:
    Only for 10 years! ;)
  13. Agile
    26 Jun 2004
    61,271
    Thanks Received:
    4,282
    London
    Country:
    Odd that he does not say what their fixed price is for this model in Sheffield ???
  14. gazthepottertonengineer
    21 May 2005
    1,294
    Thanks Received:
    134
    Country:
    Probably as I haven't got the foggiest! :p
  15. Agile
    26 Jun 2004
    61,271
    Thanks Received:
    4,282
    London
    Country:
    Dont you have the price list on your laptop?
    How are you meant to tell the customers?
Loading...
Share This Page
