In Need Of help Page Baxi Bahama 100 (Boiler Problem) We have the Baxi Bahama 100 Boiler installed in our flat. Today (09 Jan 05) it was noticed that the boiler had a water leak coming from it.
Everything was working fine heating was on, water was working fine. The shop underneath our flat have been doing some work (noisy at that) and since then the water coming from all taps and the shower initially start but after it fires a little clogged up water at us. When we noticed the leak, we took the cover off and found that some plug had come out. when we put this plug back in the boiler ceased to heat, The flame light on the front of the boiler isnt lit, however neither is the problem indicator. The pressure has stayed constant for the time being. but no water is being heated, It makes the usual noises like it should be heating the water, but still to no avail. any ideas how to get the boiler heating again,
